Mail-Order Dyno Tune
You're talking about a shop having an engine on the dyno, ready to make changes at request, with a variety of cams, heads, displacement, etc., all for a mail order tune, that usually sells for anywhere from 75 bucks to 250 bucks. In all reality, something like that would cost more than a full chassis dyno tune. Heck, just to put an engine on an engine dyno is usually 800 bucks plus.
BTW, what is a "Katech quality tune"?
When you have run the car across the emission rolls with a final end calibrator, then and only then do you have a complete sellable calibration.
Then you ship the car to the dealer, sell the car and realize that some customers in Northern MN are complaing about cold starts, so you do a manditory cal change. Then, some other customers in Phoenix complain about something else and you make another manditory cal change.
Sorry for the long statement, but I think it gets the point across. To change your engine even 50hp over stock really requires a new calibration. Yes it will work, but it will not be 100%, more like 65%, and the more you add the worse it gets. So, get your parts, and go through the steps mentioned and it will be a GM quality tune!!!
I have done the same setups on many cars and get much variation. If you are into even basic physics, you understand that the slew of variables actually means that no two can be the same.
What the major difference between GM and ford guys. GM engines are big, respond great to a heads/cam package, and run a SD/MAF based system. Fords are "MAF" based, some alpha N backup, but basically maf only, with the maf in an intake track, not located 2" from the throttle body.
GM guys run heads/cams are basic mods. They make great power, and require real tuning. Each setup is unique, with lots of head options, lots of cam options, lots of exhaust options, ect.
Ford guys run basic boltons, (intake, exhaust, pulleys, cai, ) and then go to forced induction. That's the most logical way to make power on a mustang. There are no "400 rwhp" cam only guy, and no "50+hp" cams on stock fords.Once you install an aftermarket forced induction setup on a car, you need real tuning. You can get close through mail order, with datalogging, and a wideband. Some ford tuning companies provide thier dealers with real starting points, forced induction value files, maf value files, injector value files (all based off of real flow data...) that make dialing in a combination much easier. GM guys are all based off of the starting point thier tuner has, the tuning companies provide software, (diablosport may be the only exception, i have never seen CMR in person for any gm applications)
Ryan
Ryan
I recently did an LT1 mail order for another shop. They loaded the tune, then called me and told me it would hardly run. He had to jack the MAF table up in the lower portion by like 80% to make it idle. Then it was idling at like 1800. I spent some time on the phone with them (I kept telling them it had to have a vacuum leak) and finally, after they found the problem (vacuum leak) he loaded my tune back in, and said it ran damn near perfect (cammed, LT4 heads, intake, etc.)
Moral of the story, when it comes to mail order tuning, you CANNOT account for the uncontrollable variables. The tune can be PERFECT for the setup, based on a controlled, engine dynoed, exact duplicate, yada, yada, and if you plug that tune into a car with a problem, well all of a sudden, the tune's not worth crap.
