Tunning ?
Old Mar 16, 2010 | 08:45 PM
paul12001's Avatar
Default Tunning ?
hey guys have a 96 z with a .612 cam in it and it always seems to die after i get on it and then come to a stop it was tuned but not sure the shop did the best job. I know its a big cam but can a show retune it and adjust it so it doesnt die like this at idle?
Old Mar 17, 2010 | 08:45 AM
paul12001's Avatar
anyone?
Old Mar 17, 2010 | 08:59 AM
Old Geezer's Avatar
Perhaps more info, such as what engine, trans, etc, would get you some help??
Old Mar 17, 2010 | 09:11 AM
35thredz's Avatar
I would take and put it on a dyno and have it tuned. You could buy tunercat software for LT1, and learn to fine tune it yourself.
-Dan
Old Mar 17, 2010 | 09:47 AM
B4Cya's Avatar
Tunercat is for OBDI cars and his 96 is the first year of OBDII.
It takes a decent amount of tuning work to teach decent street manners to a big cam. There are a bunch of maps that need some attention
Are you running bigger injectors?
Old Mar 17, 2010 | 10:59 AM
01Z28M6's Avatar
C.A.T.S. (Tunercat) also has an OBDII version.
Old Mar 17, 2010 | 03:34 PM
paul12001's Avatar
LE2 heads and 228/234 .612/612 109 lsa cam 37lb injectors walboro fuel pump, 1.6 rocker arms and new pushrods Patriot Gold Extreme springs (155 lbs seat and 400 lbs open) Manley 2.00/1.56 6000 series valves Steel retainers and locks
205 cc intake port
milling, cleaning and assembly
flow about 275/190 CFM
6 speed trans
Old Mar 17, 2010 | 04:01 PM
flame's Avatar
They sold it to JET a couple years back
Old Mar 17, 2010 | 04:03 PM
flame's Avatar
Go back to the place that tuned it and see what they will do. Most places will work with you to get it right. Not many have required software to do the 96-97 LT1.
