im stuck in sears parking lot need help ASAP
so i just hooked up my n2o system last nite but didnt try it so i was in sears parking lot waiting for some one i wliped the switches on & pused my purge button & it did nothing so i was going to look into it when i got home. well i turned my key on & its like there no power to the ingnition now. i checked the fuses & switched the ingn. realays out with the fan relays & still nothing. theres powere the i can here the fuel pump turn on but my gauge cluster is dead. did i fry the computer? any help would be great cuz i got an apointment in an hour
Shure sounds like you pulled power from the wrong place and blew a fuse. Or burnt up a wire. How do you have it wired? Without knowing what exactly you did all i can say is check each fuse agin
i have the relay nxt to the power terminal on the drivers side & thats where i grabed 12v to the relay from. i ran my wires from there to the switches in the counsel. i grabed a 12v power source from the empty toggle spot nxt to the fog light toggel. i ran my other relay for the bottle heate & all that stuff i just put in the counsel to. all i did was turn the heater & the arming switch on & press the purge & the illuminated switches went out like i poped a fuse
i pulled the all out. ill have to go get a test light i suppose & do it like that. it sounds like a fues to me or a relay but i swapped the fan relays for it ignition & starter relay & didnt do anything
