Which stock GM vehicles use 42# Delphi injectors @ 59 PSI?
http://www.marcintology.com/tuning/injectors.xls hope u hve excel
Thanks, but, the injectors are 42# @ 43.5 PSI. So, now I'm scrambling to figure out if I can raise the flow rate table so that they'll run leaner. Thanks for the post, it is helpful. Was also able to open the xls file from Wntstogo100, but, it's a spread sheet that calculates flow rate from input variables. The program used only opens excel, it won't allow me to enter anything. Regardless, the tables need to be tweaked if there's even a chance to get them to work.
I have another thread asking if increasing the flow rate values will lean the now approx 50# injectors enough. As of yet, there have been no replies.
