Random Misfire After Mac Header Install
Old Jan 15, 2004 | 12:23 AM
Braun's Avatar
Default Random Misfire After Mac Header Install
I just installed Mac Headers and catted y-pipe, and changed spark plugs (Bosh Platinum 4's) and I am getting a code p0300 (random misfire).
When I start the car up it takes about 10-20 second before the service engine light turns on. The misfire is very obvious, the car even backfires. The car runs poorly throughout the rpm range, it is so bad that if I put it in sixth gear the whole car shakes badly. When I accelerate the car stumbles.
I checked to make sure the spark plugs were in tightly and the plug wires were properly attached to the plugs and coil packs. I also checked to make sure the oxygen sensors were all screwed in tightly. I used the Predator and it had a list of 30 error codes, but none of them set off the service engine light. Some of the codes were odd : speed sensor off, engine coolant too cold for close loop, etc.
I am all out of ideas, and I would appreciate any help thanks in advance.
Old Jan 15, 2004 | 12:50 AM
2002SilverWS-6's Avatar
I don't know anything about your Bosh plugs but if you are able to check the gap do that first. Maybe you could of cracked a plug or something putting your headers on. They can easily break. You probably paid alot for your plugs but alot of people use NGK TR55's and they only cost $2 each. Just recheck everything again. I know it sucks just hang in there. Also did you have any codes before the header install. Good luck. Maybe change plug wires too.
Old Jan 15, 2004 | 01:22 PM
BayouVette's Avatar
i had two cracked plugs after i installed my headers..
Old Jan 15, 2004 | 01:31 PM
Steve98Z's Avatar
Default misfire
Did you check the plugs for cracks before you installed them? I have seen plugs come stright out of the box with the ceramic cracked, also when installing headers it is very easy to beat the plugs up. Just my opinion, I would pull those POS plugs and put in some tr55 or tr6's.............
Old Jan 15, 2004 | 02:54 PM
Braun's Avatar
Thank you all for your advice, I will replace the plug when I get out of class Friday. On a side note, all the codes are gone except the ones I always have.
Old Jan 15, 2004 | 09:17 PM
WS6FirebirdTA00's Avatar
how fast did this happen after the header install? maybe a wire could be burning, didnt see if u said u checked or not but figured i woudl throw it out there
Old Jan 16, 2004 | 08:57 PM
Braun's Avatar
Thumbs up
Well guys, the verdict is in there was 1 very cracked plug. Again thank you all for your help. What makes it even better is now my clutch is broken in so I will be .
Old Jan 17, 2004 | 02:30 AM
Your welcome.
