Check Engine Code
Old Jan 24, 2004 | 06:13 AM
Z0603's Avatar
Default Check Engine Code
Yesterday I got my check Engine on
I plugged the Diablo Programmer and went to Diagnostics-DTC Information-Check all DTC’s – and I got
Fault 1 of 6
P0133 O2S Circuit,
Bank1- Sensor1, Slow Response.
I know now that the problem in the O2 simulators but how the problem happened and why I have no idea.
I have SLP Long tube headers with H pipe balance tube and H down pipe with no cat converters and have installed the O2 simulators to not get the check engine code but now and after 1000 mile run after the installation I got the trouble code.
Please for who knows
What is the problem?
Why is the problem?
How to fix it?
Old Jan 24, 2004 | 07:47 AM
Orange99Z's Avatar
Bank 1, sensor 1 is the driver side front sensor which should be in your header. The O2 simms are for the rear sensors which would be bank 1 or 2, sensor 2. It might not be the simms.
Old Jan 24, 2004 | 08:39 AM
wrencher's Avatar
wrencher
Fault 1 of 6, what where the other 5?
Old Jan 24, 2004 | 11:09 PM
blk~2000~Z28's Avatar
I agree. Have you had any missfires? I got that same code but only after some missfires. Tell us the other 5 code numbers.
Old Jan 25, 2004 | 04:27 AM
Z0603's Avatar
I had no missfires and nothing was wrong with the sound, power or anything else ... everything seems to work normally .. I just have this check Engine code on and when I checked it with my programmer that what it gave me
Fault 1 of 6
P0133 O2S Circuit,
are you sure it's not a problem with the right side O2 sensor ... you don't think it may be plugged uncorrectly or something like that or it may had some electrical problem?
Old Jan 25, 2004 | 06:09 PM
wrencher's Avatar
wrencher
I am not familair w/ the diablo, but is there a up of down button to scroll thru the results?
Generally if it says 1 of 6 there is more........
Old Jan 25, 2004 | 06:14 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Exactly.
It is definatly not Sim related if it's the front O2 (sensor 1), unless you plugged the sim into the front O2 spot.....
Old Jan 29, 2004 | 03:05 AM
Z0603's Avatar
I checked it today and I got
Fault 1 of 10
P0133 O2S Circuit,
Bank1-Sensor1, Slow
Response.
Fault 2 of 10
P0134 O2S Circuit,
Bank1-Sensor1, No
Activity detected.
Fault 3 of 10
P0135 O2S Heater
circuit, Bank1-
Sensor1, Malfunction.
Fault 4 of 10
P0137 O2S circuit,
Bank1-Sensor2, Low
Voltage.
Fault 5 of 10
P0141 O2S Heater
circuit, Bank1-
Sensor2, malfunction.
Fault 6 of 10
P0153 O2S Circuit,
Bank2-Sensor1, Slow
Response.
Fault 7 of 10
P0154 O2S Circuit,
Bank2-Sensor1, No
activity Detected.
Fault 8 of 10
P0155 O2S Heater
Circuit, Bank2-Sensor1, malfunction
Fault 9 of 10
P0157 O2S circuit,
Bank2-Sensor2, low
voltage
Fault 10 of 10
P0161 O2S Heater
Circuit, Bank2-sensor2, malfunction
here is all the fault the diablo tuner showed
Old Jan 29, 2004 | 09:19 PM
WS6FirebirdTA00's Avatar
looks like its all screwed up, might need new sims and new front o2's. see if any wires were burnt on the headers, make sure they are all pluged in too.
Old Feb 2, 2004 | 09:41 AM
SSN8R's Avatar
How long have you had the headers???
Old Feb 4, 2004 | 01:47 AM
Z0603's Avatar
almost 6 months but i only had about 1200 miles on the car since i had them
