IAT Sensor required for Speed Density?
I am going to be running speed density, I have a custom harness made with no o2's, or MAF. However I don't know if I will need a IAT sensor. I know that it is a great tool to have when it comes to tuning(I already have EGT and Wideband o2 sensors) but will I need it? Essentially the car will be tuned 1 time, running 1 open-loop tune, so will i need it for anything other than the tuning process? This setup will be Naturally aspirated, and may see a small shot later down the road.
So do I need to buy the sensor and install it? Or can I just run the car without the IAT. If I do need to get it, I found I some information Here about putting it in the EGR provision in my intake manifold (old FAST 78mm). Anyone else feel this is a good spot to put it? I know people often do that with FI so the sensor doesn't blow out of the charge pipe.
Thank you
Make sure that the ENTIRE VE Table is properly tuned with a WBO2 if it is going to stay in OLSD.
As far as the location of it, I have no experience with running the sensor in the intake manifold.
The car should be a blast to drive! Let us know how it turns out.
as your in-taken air is also ducted from outside. What you
want is a good representation of the ingested air, without
influence from the engine bay surroundings. But there are
many "cold air" schemes and not all of them are that good,
in the respect of minimum temperature change from outside.
"Free Ram Air" and SLP CAI being a couple of the worst.
A/F swings a bit with the colder weather, but it isn't tremendous. I have an onboard WB.
It is preferrable to have it hooked up, but the car will still run fine if you don't.
