Install pic of threaded IAT sensor in EGR hole and 4" MAF.
Old 07-02-2006, 09:47 PM
Coal Mining Director
onfire's Avatar
Default Install pic of threaded IAT sensor in EGR hole and 4" MAF.
I was surprised that both went in easy. Time to retune.
Attached Thumbnails Install pic of threaded IAT sensor in EGR hole and 4" MAF.-img_0286-medium-.jpg
Old 07-02-2006, 09:51 PM
frcefed98's Avatar
Looks Killer, I think i'll drill and tap my intake for my threaded IAT sensor too. Best place for a IAT reading i'd think.
J
Old 07-02-2006, 09:57 PM
onfire's Avatar
J
Don't have to worry about it blowing out under high boost that way.....can't wait to get my alky kit to try out.
Old 07-03-2006, 08:47 AM
Fire67's Avatar
Wont the alky coming in through the TB affect the readings of that? The IAT would come in direct contact with the mist.
Old 07-03-2006, 09:11 AM
onfire's Avatar
That's why I relocated the IAT to the intake. I WANT the alky to hit the sensor....that way I can tune the timing vs IAT table to pull timing if the alky kit fails....if the alky is flowing = cool air = more timing = more power. If the alky kit fails = hot air = less timing = saved engine.
Old 07-03-2006, 11:00 AM
67Firebird455's Avatar
That is a freakin awesome setup. Where'd you get the threaded IAT though? I was wondering how the F I was going to pick up IAT on my setup.
Old 07-03-2006, 11:53 AM
onfire's Avatar
Sensor is a GM# 25036751 for $38 through GM (for a 1991 Syclone). 3/8" 18npt.
Adapter is a LPE map sensor relocator for c6 vettes...the map sensor hole has to be enlarged on a drill press and tapped for 3/8 18npt for the IAT sensor. LPE # LN-BK28kit for $67
Then it just presses in the egr hole (has a oring seal) and the the retainer screws into the existing screw hole for the egr.
Old 07-03-2006, 12:10 PM
Ping King's Avatar
running a scavenge pump? what kind is that?
Old 07-04-2006, 02:36 PM
onfire's Avatar
LPE scavenge pump
Old 07-05-2006, 09:40 AM
Fire67's Avatar
Ok, I see what your goin for there, but wont the iat temps be incorrect if that gets wet. (Im thinking along the lines of blowing on a wet finger, then a dry finger. notice the diff.) The air temp would be the same but the wet sensor I would think would read colder than the air actually is.
Or does that not matter... As long as the timing is correct for what the IAT sensor reads I guess it'd be fine.
Very cool concept, I like how it sounds... Use the PCM to make sure you dont blow your modded motor if/when the meth fails.
Old 07-05-2006, 01:55 PM
WestSide's Avatar
$100 to fit the IAT sensor there? There has to be another similar way that isn't so expensive.
Old 07-05-2006, 09:52 PM
eb02z06's Avatar
If your doing this on a LS6 intake can not just drill and tap it?
Old 07-07-2006, 10:42 AM
bczee's Avatar
Well this work for non Force Induction?.. Will moving the IAT To the EGR Port cause any bad or drivablity problems.
Thanks
Old 07-07-2006, 11:14 AM
MiaSSmaro98's Avatar
cool theard, but wats that pump a dry sump system or scavenge pump?and were and how was it?
obZidian's Avatar
...about tht 4" maf, Is that a custom piece 'enfuego'?
Old 07-07-2006, 12:14 PM
yeah how come u didnt go speed dens?
Old 07-07-2006, 07:19 PM
onfire's Avatar
If the material is thick enough at the egr location, you could....FAST was not.
Old 07-07-2006, 07:21 PM
onfire's Avatar
Thanks
It would work but not be optimal due to heat soak from the manifold. I'd want the IAT sensor close to the airfilter for NA.
Kleeborp the Moderator™
MeentSS02's Avatar
Do instructions come with the Lingenfelter piece as to what size hole to drill in the manifold? Also, could you shoot a picture with the throttle body open to see how far in the IAT sensor sticks? I'd appreciate it...
Old 07-07-2006, 07:22 PM
onfire's Avatar
Scavenge pump for the turbos.
Quick Reply: Install pic of threaded IAT sensor in EGR hole and 4" MAF.
