Anyone with a Frost tune have bucking?
My engine is new including EPS cam and ported 241's. I got a mail-order tune (not Frost) to get it fired and I've tweaked it w/ EFI Live for the last couple weeks. It idles decent and the VE tables & MAF are pretty close. But I have bucking & surging in 2nd / 3rd / 4th gear at light throttle between 1400& 2000 with the original tune and after my tweaks.
I'm just wondering if I should throw in the towel & get a Frost tune like I probably should have to begin with. But if I'll still have bucking with a Frost tune then I certainly won't spend the money. What do you guys think?
Ya, I'll probably get in touch with Steve, I'm just curious to see what others have found. The cam is not that big - 226/230-113 - it lopes a little at idle and only has +2* overlap. Before picking the cam I read a lot of threads about cams that size and guys were saying the car drives like stock after a good tune.
If you follow both of these tutorials, you should be able to get rid of the issues. That cam is not too big.
It took me a while tweaking, but I was able to get mine pretty smooth. Follow SSpdmon's steps and you can get it.
Also use the MAF flow for desired airflow, not the raf method. It seems to help.
Good luck.
http://forum.efilive.com/showthread....ul-Info-Inside
http://forum.efilive.com/showthread....ips-amp-Tricks
Good luck.
Thanks bmax. I had gone thru AutoVE, AutoMAF, RAFIG, & SSpdmon's tutorial but still had bucking. This morning I redid AutoVE & AutoMAF. They were pretty close but needed a little tweaking. Now the bucking problem is a little better but not completely gone. I've attached a tune & log if anyone would like to take a look. Thanks.
LS1Tech Sponsor
LS1Tech Sponsor
Nothing can ever replace getting a good dyno tune. You shouldn't have to live with surging or bucking with a cam that mild. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
I didn't expect my mail-order tune to be perfect. But I expected to be able to do some fine-tuning on my own and dial it in. It's worked out quite well for the most part. It fired right up, idled ok. I think I've made some gains but I have a lot to learn to get rid of the bucking. Maybe I'll never get it myself, there are so many variables. So I appreciate your offer to help and/or remote tune. Cheers.
