New design 4L60E has different electronics 2008+
Well It looks like I'm going to give up on this 2009 trans and start hunting for another of the correct year(around 2001).
I came accross a thread in the "Performance Trucks" at the top of the page here that had gone through this same issue. They wound up swapping the valve body and many other parts over on the trans to make it work. I dont want to waste this low mileage trans. So I will just sell it to get the one I need.
Thanks again to everyone that help and provided information!
This may be a key here.
I have now decided to swap to a 4L80E just to get this thing together so I can drive it. I have purchased the 4L80E and needed parts. As I'm preparing for this trans to go in with the speartech harness kit, it appears to have a lot of similarities to the '09 4L60E trans that I just took out of it. Like the ISS...
I guess I need to slow down... but I dont see that happening. Too much being requested...
I guess I need to slow down... but I dont see that happening. Too much being requested... I posted a similar thread a year ago:
https://ls1tech.com/forums/automatic...-solenoid.html
My solution was to buy a newish (2001?) 4L60E core, remove the throttle body from it, and use it in my 2010 4L65E. It worked fine! I installed a new wiring harness, solenoids and pressure swithc for a 2005 4L60E. I also installed the TransGo HD2-C shift kit at this time. I used the throttle body spacer plate from the 2010 4L65E. I have put thousands of miles on this Franken-trans and 50+ track runs without problems. I'm sure there were other details, but it was doable. IMHO, other than using a 2009+ TCM, I don't think you can get a PCM to control the trans. The 3-2 solenoid and all the related hydraulic lines/logic are missing from the 2009+ valve body; perhaps the 2009+ TCM is now performing this logic.
EDIT: Correction 1 - I mean to say "valve body" not throttle body.
Correction 2 - I used the separator plate (not throttle body plate) for a 2001 trans. I did not use the 2010 separator plate; good thing because I just learned that it has an extra hole (called PE?) which would cause problems with a 2001 valve body.
I appreciate you sharing your experience. Thats good info.
I wound up just putting in a 2002 4L80E for durability as a truck to tow my Carmaro around.
Bringing this thread back from oblivion
I'm having this same issue now. 2010 4L60E with 2005 PCM in a swapped S10
If I don't mess with the tune, the trans shifts from 1st to 3rd and stay there, not 4th. Will not downshift until truck is turned off and restarted.
If I delete the 2 trans DTCs (P1018 and P0785), then it behaves different. It will start and stay in 2nd no matter what. Will not upshift at all.
I can command the shifts using HPT scanner and all gears work as they should, even the TCC works. This made me think this problem could be solved with tuning, but I have used every OS I have without success. Tried all settings in the tune but PCM isn't using the shift tables. Deleting DTCs only made things worse.
Every solution I found on Google was to change the trans to a pre 07 model. Im sure the PCM can control it since it upshifts and downshifts fine with the scanner, however something is bothering it and it's just not commanding the shifts. Like a limp mode
Does anybody have new information?
Thanks
Thanks
Thanks
Thanks
Maybe someone else will reply with a different experience also.
While I am sorry to hear that your efforts were for naught, it is good to learn that this issue cannot be "tuned" away.
How did you deal with the harness/connector changes?
The 2010 uses a mechanical shifter switch instead of the Manifold Pressure Switch; I don't know how different that looks to the PCM.
Getting a compatible valve body is easy - I have bought several from ebay seller "powertrainpartsplus"; I see a nice '08 there now for $68 and a '03 rebuilt one for $150. You will also need the separator plate - Transgo 46-PLT-96, gaskets and a new internal harness for the Manifold Pressure Switch.
PM me if you want me to look at links for other Valve Bodies, or want to call me to go over everything.
Well, for the connector changes I just compared the two diagrams, one from 2005 and the other from 2010 and made the changes. Pretty easy, the trans connector can be disassembled and the pins changed.
I'm thinking the limp mode in the PCM is what makes this problem un-tunable. Since I can make the upshifts and downshift and control the TCC in the scanner, the PCM should be able to make on its own, it's just something preventing it from entering the proper operating mode.
I'm going to try to simulate the missing solenoid with a resistor and test again.
Simulating the missing solenoid with a resistor sounds like a great idea.
The '96+ 3-2 downshift solenoid is supposed to be 20-31 ohms. So a 10 watt 22 or 27 ohms resistor should do it.
http://www.parts-express.com/22-ohm-...erance--016-22
You should really start your own thread, when the thread you are looking at has been idle for the last four years...
I do not believe the modern electronics 4L60/65/70/75E transmissions can be properly controlled by older generation PCMs/ TCMs.
There is just too many electronic changes between the different year transmissions.
The older units (excluding the first few years) have:
-Fluid pressure manifold/ switch assembly with thermistor
-Fluid pressure control solenoid
-First-Second shift solenoid
-Second-Third shift solenoid
-Third-Second rate control solenoid (PWM)
-TCC apply solenoid
-TCC rate control solenoid (PWM)
-Output speed senor/ vehicle speed sensor (in transfer case on four wheel drive vehicles)
As well as a Park/ Neutral and Reverse lights switch assembly.
The newest units (2008 and up with change-over in 2006-2007) have a different valve-body and have:
-Internal mode switch
-Input speed senor
-Fluid temperature sensor
-TCC apply solenoid
Going to an aftermarket/ standalone controller works well and has become quite simple for the last decade if not longer.
For an inexpensive solution that works well; I would recommend the: US Shift Quick 4 controller.
The controller is aprox. $600.
If you are not able to produce a wiring-harness for yourself... expect to pay an additional $150.
Good luck!
-TCC apply solenoid
-Input speed senor
-TCC apply solenoid
Good luck!
