For n/a cammed cars, what do you aim for idle?
There's no right or wrong answer, just do what you like and what the engine wants.
A lot of people idle as low as they can because they like the lope sound. Personally, I like the engine to be snappy so I aim for a higher idle speed. My last two 427 engines idled at 1050 rpm with 20 degrees of overlap. Most people think it's much lower by the sound.
232/234 @ 112, so 9 degrees of overlap, LS6 so 5.7L, 850 RPM
It barely sounds cammed. There are plenty of videos on YouTube from LS1/LS6s with smaller cams that sound a lot more aggressive, I assume that's from a lower idle speed and creative underspeed/overspeed idle timing compensations.
Moderator
Received 1,852 Likes
FWIW. I could get the 428 to idle at 650, but it made off idle lazier. I liked the way it drove at 975 idle speed. That was on a 248/255
My 346 on a 237/245 likes to idle at 975
Edit - light clutch so that influenced it some I am sure
226/232 110 LSA on a 4.8 on E85 starts to surge if I idle it below 900-950 hot, so I idle at 1000.
It also revs much much cleaner idling at 1000 than 900, and has less issues idling in gear.
Vibration is a lot less at 1000 than 900. I see no reason to lower the idle.
my cam has 88 degrees of overlap and i idle it at 850-1000 very reliably. it could be much smoother but i tweaked some stuff in the tune to make it sound 'better'
468 inches eat it up. it runs like *** under any kind of load below 2000rpm, but its never stalled(except when i mess up the third pedal) or hesitated and the throttle response is insanely quick. i put 3.90s in it and its worlds better, i still dont shift to 6th until 70 and can go 90 at like 2400rpm but its way better around town and you know, its my only driver so thats important
Moderator
its approximate seat to seat. i know the 050 and lift numbers but not the actual lobe or manufacturer, so i cross referenced to comps lobe catalog and found a couple examples of lobes matching the 050 and lift and used those advertised numbers to calculate my valve events. im blindly confident that it is within a few degrees of 88 at worst. i mean, it idles at 84-87kpa. i am in the middle of completely reworking my eoit tables, so im hoping to at least pick up a little bit of economy. it gets 15 highway now...
