ABS inop, Traction control off, and Low traction light come on
Hi
I was driving home from work on Friday and all three lights came on when driving on the highway. I scanned the car with my HP tuners and i got the following codes:
[Brake] C0045 - LR Wheel Speed Circuit Malfunction (History)
[Brake] C0046 - Brake Pressure Sensor A/B (History)
[Brake] C0245 - Wheel Speed Sensor Frequency Error (History)
Has anyone encountered a similar issue? Does anyone know how to fix the problem?
Any info would be great
Michael
Michael
I finally got around to replacing out the two abs sensors with new one and the following lights are still on:
ABS Inop
TCS OFF
I have no control over switching my TSC off or on. It just stays off all the time. I would like to get this corrected. Any info would be great!
Thanks
Michael
ABS Inop
TCS OFF
Thanks
Michael
Mine was a bad ground. It blew the fuse (one next to ENG SENS) IIRC. Bought new bolts and washers for the two grounds on the rad support, cleaned up the other two grounds in the front replaced the fuse and haven't had a problem since. GL man.
