98 to 02 ECU with EFI live
Jay
Jay
the pcm is physically different(different hardware and different pin inputs and outputs), so you need to have a 99-02 pcm to use the 02 OS...
the 98 OS will not take the 02 OS and it will become a brick if you somehow got it to write to it.
you can use your 98 harness...but you need to basically pull all the pins and put them back in to the connectors to match up for the 02 pcm pinouts...its not an easy process, and you really need to take your time with it to get it correct.
mos of the tables will copy using the the compare window in HP Tuners...
some will have to be manually copied and pasted...
https://ls1tech.com/forums/pcm-diagn...001-pcm-2.html
may give an idea whats needed in post 23 but will take some more looking
https://ls1tech.com/forums/pcm-diagn...uel-gauge.html
but you can use this as well http://www.chipsbyal.com/convert98/
ive used it on a couple just to simplify things less thinking on my part.
for me it still made the harness look jumbled and unclean.. I went back and just depinned and untangled each wire at a time for a direct shot out of the main harness to its new home. made it much cleaner.
