Knock retard
Old Sep 3, 2012 | 09:07 PM
2000 TA owner's Avatar
Default Knock retard
Question wot run have 3* retard giving me 20* timing that seems low to me I have a predator tuner can I adjust wot spark of course after I fix the knock retard Im thinking I should be at 26,27* timing any help would be appreciated this is a 93 slp tune
Old Sep 4, 2012 | 12:08 AM
therealcreeper's Avatar
the correct amount of timing depends on a lot of things
what kind of mods do you have? need more info
Old Sep 4, 2012 | 09:52 AM
jimmyblue's Avatar
Moderator
If you have a ping problem then jacking the timing will get
you more knock retard. You have to get to the root of it
and do so before you hurt something. Though 3 degrees
is not much.
Old Sep 4, 2012 | 10:03 AM
jrob56's Avatar
I know I had some timing being pulled last time I was out at the track. No matter what we did, anytime Id get a good launch itd knock and pull timing. Turns out my headers(1 7/8) are hitting the Kmember even with poly mounts. So some more trimming is in order. My advice is to make sure nothing is hitting!
Old Sep 4, 2012 | 05:48 PM
2000_SS's Avatar
could also be bad fuel...if you have a pretty aggressive timing table and got some fuel that was a few octane point lower than what it was tuned with, you'll get knock.
Definately need to check for clearnace issues or loose parts or anything else that could cause false knock. you don't want to put more timing in it if its legitimately knocking.
Old Sep 4, 2012 | 09:06 PM
everything is stock exhaust included 3.73 gears slp7196 93 octane tune not hearing anything and I have been around drag racing my hole life so dont be afraid to give me advice just first time with the tuning and fuel injection LTFT is at-1.5 had to take 7 out to obtain that then took 3 out of pe I will fix the knock problem first just think even after that 23* seems a little low any help would be greatly appreciated
Old Sep 5, 2012 | 06:10 PM
anyone
Old Sep 5, 2012 | 08:39 PM
jrob56's Avatar
Originally Posted by 2000 TA owner
anyone
Plugs and wires? Bad coil?
Old Sep 5, 2012 | 09:11 PM
wws699's Avatar
Mix some 100 unleded with the 93 and see if it goes away. If it doesn't then you can rule out bad fuel....
I would check plugs and wires first though.. How many miles are on the car? You might have some carbon build up.. When was the last time you used Seafoam?
When was the last time you cleaned the MAF wires ?
Old Sep 5, 2012 | 10:28 PM
boostit5.3's Avatar
fuel filter? pump?
Old Sep 5, 2012 | 10:35 PM
the 100 octane fuel is next the car only has 62000 miles car runs well just first time I logged it at the track and got the knock runs 13.40 @ 103.7
Old Sep 6, 2012 | 07:45 PM
wws699's Avatar
If your car is an A4 your trap speed is normal for a bone stock LS1.
If its an M6 your down on power.
Old Sep 7, 2012 | 07:41 PM
ScottyBG's Avatar
Could be a bad knock sensor? If you put good fuel to it, and it doesn't change, it is probably false knock.
Your timing expectations may be a little high? I can't run 26 or 27 degrees of timing in my car on 93 octane, about 23 is all I can get before knock becomes a factor, and that's running a 6 heat range plug. All of our engines are unique, so your ideal timing might be different than what you have seen others run.
