Hard starting on first crank
Do I need to add more fuel when cranking? If so what is the best way to do this? the cranking ve table? Why does it always fire up immediately on the second try? Never on the first crank. I even cranked for several seconds and still wouldn't hit. Stop and try it again and immediately fires.
For a little info on the car it is full bolt on's with a cam, and I have converted it over to e85. I have pretty much everything tuned in and running great, except for this starting issue.
I have even cycle the key twice to make absolutely sure the pump has the system primed and the first time i try starting it when cold, it won't start. Thus why i believe it has to be something with the tune.
But that doesn't make sense either cause how could you command a .995 a/f ratio??? that is stupid rich.
Engine>Fuel>General>Cranking Fuel>First Pulse Mass
Try increasing this table and see if that helps your start problem on first crank.
Other tables to increase are:
Engine>Fuel>General>Afterstart Enrichment>Initial Adder vs IAT and or Initial Adder vs ECT
Play around with these and see if any of them help. I've gotten mine better but sometimes still doesn't crank on first try. Always will on second try though.
