hanging idle and car wont idle at target idle
2000 formula bolt on car, stock heads, stock cam, ls6 intake, lt headers, fipk, p&p tb and maf housing. i have the car running within a 2% error on the ve and maf tables but now i have a hanging idle issue when coasting. when coming to stop and i push the clutch in the car will hang around 1200 rpm untill i few sec after i come to a complete stop then it will drop to around 825. i raised the throttle cracker enable speed to 25mph and it did nothing, i zeroed out the throttle cracker table and it did nothing so i am lost with what else to try there. i also am having problems with the target idle speed. i changed it to 650 above 140* and did a entire write of the tune and it still idles at 825. i checked to see if the tb blade was closing all the way an it seems to be fine, i tried to adjust the idle screw on the tb and if i put it any lower the tb blade will just stick so i am assuming it is good. my tps reads 0% at idle. so i am at a loss at what to do next. i am new to tuning but the only things i can think of is my idle airfow is off since tuning the maf an ve or my idle spark is to high. i will post my tune and final log when i get home from work. any thoughts in the mean time?
i ran the russ k cofig and fixed the hanging idle problem by zeroing out and setting the throttle cracker enable mph to 255. now i just have to figure out the reason i cant adjust the idle. i am going to clean out the tb and iac this weekend and see if that fixes it. today i checked for vaccume leaks and found none.
i also noticed today when scaning i tried to force the idle down with the vcm controls but it still would not go below 825, i think when i comanded 500 it was idling at 800.
not sure on the hole. im gonna plug the hole today an see what happens. friday im gonna take the tb off and clean all the crap out of it. is there any way to check the iac?
not sure about count but the iac position was at 180 at start up cold on slowly worked its way down to 0 at 120* and stayed there in the idle config i posted above.
the throttle blade is as close as its gonna get. i took the tb off yesterday and cleaned it out and cleaned the iac sensor out (they wasnt that dirty) and put them back on and it didn't really help anything but i noticed the hole in the tb looked a lil big so i put some gorilla tape on it an it went right down to 650ish where i have it set. i took the tape off an put a screw in the whole with a lock washer and nut with some red loc tight and ground it down and it seems to be good for now. prolly just look for a shaner ported tb that hasnt been drilled to replace it. i will have to wait till i get hpt back from my buddy to make sure its working right.
thanks for all the help guys
the tune is fine. i put the stock tune back in it and tried to lower the rpms and it still wouldn't go down past 825. i just never noticed there was a problem till i got hp tuners and tried to lower the rpms.
which ported throttle body do you recommend?
