Holley EFI Dominator Questions
I have been reading up on aftermarket ECU's being piggybacked off the stock ECM like the BS3. Brian Macy from horsepowerconnection said that he could make a piggyback harness for the stock ECU on my car that will connect to the Holley EFI. I am hoping that this will allow the stock gauge cluster to work, control the alternator, and AC compressor as well.
My hopes of having that done is that when I go get the car smogged the smog tech will just connect to the ODB2 port and the stock ECU is still thinking it is running the motor and all will be good. Can anyone shed light on if this is true or not? If not how does everyone get their cars to pass emission with an aftermarket ECU?
As far as electronics go that ecu is from 1999 it might as well be a packard bell 486 running my high dollar motor when I could have the new 2012 efi that is more along the lines of an i7 intel quad core processor.
Your stock PCM can do what you need, as Ed has already mentioned. If you go ahead and do this, somebody that knows what they are doing can program your factory PCM to not set codes, and report all your emissions flags as run and past.
$800.00? Damn! I have been working too cheap! LOL
I have bought the Calibrated Success DVD and the tuning school beginning course. Is there any other courses or books I should buy to help me learn how to tune?
In all honest I would rather spend the money to learn something than to keep paying someone else to do it for me. I have no problem paying someone to teach me either.
Back to your question re: stock and aftetmarket ECU tuning. Factory PCMs are very powerfuland offer alot of tables that allow tune refinement. What they lack are realtime tuning capability and external controls (boost, water/meth traction etc). At minimum you should consider EFILive or HP Tuners and integrate a WBO2 sensor.
As for the Dominator EFI, its quite powerful, offers realtime tuning and I have to disagree but, the self tuning main fuel map works quite well. There are still tables that require tuning such as Accel Enrichment and cold start fueling but again, these are real time tunable with a fairly easy user interface.
My problem that I had with the stock ecu was the fact that it couldn't handle large injectors and once you hit a certain point you need a larger injector. With the LS2 at the time if you needed a larger injector like the 83lb hr injectors like I was using you needed a low impendence injector which meant I had to use an injector controller box. That isn't even mentioning the fact that the stock injector flow rate table would max out at I think it was 92 lb/hr. Which meant I couldn't even update the injector flow rate table because it was already below the injectors values that I needed to put in. I was told I then needed to scale tables by a percentage to compensate for the larger injectors. Which none of the books/courses that I have bought discuss how to do that and the people that do know how aren't willing to give up their knowledge (which I know I wouldn't either if it took me 20+yrs not to mention you are talking to a noob that will not get 90% of what you are trying to say).
I guess my problem was that I was trying to learn how to tune on a car that had been that modified was WAY over my head.
Is it worth it to keep the stock ecu and be forced later to scale tables once I am forced to run a larger injector that is beyond the scale of the injector flow rate table and loose bottom end resolution from scaling tables?
OR
Is it just better to start out with an aftermarket efi that doesn't have those types of limitations?
I would like some more input from the tuners that do this day in and day out and know ALL the short comings from both sides of the fence. I really don't want to get further down the road just to find out it would have been better to go with an aftermarket efi from the get go.
I do appreciate you guys that have responded with the insight you have provided already.
