Innovate LC1 Wideband
Ok I ordered the kit, and It came with a CD, and a cable to plug in to change setting, but the cable will not plug into my laptop! Do I need an adapter for it to plug into my USB? If so where do I get this adapter?
here is what i used for mine, there are several options but yes you need a com port to usb adapter.
Amazon.com: C2G / Cables to Go 26886 USB To DB9 Male Serial Adapter, Blue (0.45 Meters/1.5 Feet): Electronics
![Amazon.com: C2G / Cables to Go 26886 USB To DB9 Male Serial Adapter, Blue (0.45 Meters/1.5 Feet): Electronics](https://ls1tech.com/forums/images/misc/amazon_icon.gif)
Moderator
Try going to your control panel hardware find the USB your serial to USB adapter is on go under advanced and slow down the baud rate one step till it works . I had to use 9600, which was one step down from the default setting...I'm using a staples USB to serial adapter on my lc1
