Lc1 wideband issues
Heater grounds and calibration ground should all be crimped to the same ring and then grounded to get a good signal..
I'd hate to think you got a dud straight out of a brand new box
Did you try using LM PRogrammer to ensure it was setup as expected ? Note, anytime there is a sustained power loss w/the LC1, it WILL loose its settings and youwill have to reset w/LM Programmer.
Which gauge?
LC1-red -> switch/fused power
LC1-blu -> battery ground
LC1-yel -> narrowband signal (if required)
LC1-grn -> narrowband return (if required)
LC1-brn -> wideband analog signal (to logger)
LC1-wht -> wideband analog return (to logger) and pushbutton/LED cathode(-)
LC1-blk -> pushbutton/LED anode(+)
( now I use EFILive serial comms instead of the wideband analog signal/return )
No, that is not normal, it is fubar'd.
