Gen III Flex fuel Write-up
i did the p411 change with flex fuel now my cruise control don’t work I used the 02 Tahoe os and my asr light on and air bag light I’m trying to fix all these any why you guys know?
i am having the same issue. I know that there is another wire you may need to pin in that is different. I believe it is the cruise disable. I was going to try this when i had the time. Its blue 86 on the gto pin out, i cant find a pin out for the camaro that labels it the same but it might be red 83(cruise inhibit) i was going to look at the wiring diagrams for both and compare
I have a Hummer 2006 OS on my P59, so I can't tell. My cruise control work really well, everything actually, except the ASR (that's don't bother me that's much, but the Service Vehicle/ASR Off lights yes).
What if any benefit is there to having a express van pcm if you have to rewrite another OS onto it?
Secondly I’ve seen mention of a 05 avalanche flex os for a blend table. I have Silverado flex files from a 05 that I’ve already pulled and they look exactly the same as a avalanche. the number given earlier in this thread is the service number not the OS number. Just wondering as I have a Dbc p59 already and have the Silverado file and plenty of 80e files. Just was confused when they said the avalanche was optimal and I don’t see any stand out differences over the Silverado.
I also tell people to use the avalanche one because the avalanche flex OS is a known working OS that won’t act weird with the 80. Lots of people try to us a regular flex Tahoe or flex Silverado OS and then have all sorts of weird 80 glitches and bugs. It’s like there’s a weird 60 ghost in there messing things up. With the avalanche people don’t have those issues.
if you already for sure have a DBC p59 then use the avalanche flex OS and do the 80 segment swap. Just don’t forget to tell your computer you’re a DBC now and make sure you check the system options and change it all to a gmt-800 or you will probably have weird abs lights and airbag lights and stuff. It has to know it’s a truck and not a gto or corvette or whatever. (Mine would tell me I had low oil even though I didn’t and also tell me my battery wasn’t charging and it was.) in the system options there’s alternator options and what do you know? Fixed my weird warnings.
And I have 4.3 p59s laying around and of course they are drive by cable compatible so that’s why I asked
10-4. Odd on the OS issue though. The Silverado and avalanche file that I pulled had the same OS number. Do you have a Copy of the avalanche file you use that you could send me?
Sorry, I’m working off the top of my head so I think I got confused for a second.
The avalanche 2500 80 segment is preferable to the Silverado 2500 80 segment. In other words don’t try to put a silvy 80 segment in an avalanche flex segment. So I think that’s why people use the avalanche 80 segment AND the avalanche flex segment.
People just prefer the avalanche 80 segment so they just match both segments
