help
Old May 21, 2004 | 10:06 PM
SLO POK 98's Avatar
Default help
I was wondrering if anyone has HPtuner for a 98 Camaro and was having the same problem I am.....
Basically, I flash my PCM and it downloads fine, save it and then when I attempt to open it, it throws an error code saying that it is unable to read my pcm because I have a Corvette. WTF Any help here at all would be much appriciated.
Btw, we uploaded another 98z and it worked just fine....its just mine, its retarted, damn my car
Thanks
-Mike-
98 camaro disguised as a corvette.
Old May 22, 2004 | 09:42 AM
ataylors's Avatar
I would post this on the HPTuners forum, they are pretty good at responding quick
Old May 22, 2004 | 06:40 PM
SLO POK 98's Avatar
I did, about the same time I put it up on here.
Just was seeing if anyone had any ideas on any forum
Old May 22, 2004 | 08:56 PM
horist's Avatar
also you can email keith (keith@hptuners.com) and he'll fix you up...
Also connect to your car, and in the PCM Flash go to help , VCM Suite INfo and select the Get Info button... save all of this and email it to keith .. He should be able to get you fixed up really quickly then
Also... is this the stock PCM? or did you buy a spare?
Old May 23, 2004 | 01:33 PM
smeshey's Avatar
Thanks horist for giving me some info. I emailed Keith, also just put it up on their forum to see if anyone was having the same difficulties I was having. I will see what he has to say and let you know what happened.
Thanks again.
-Mike-
SLO POK 98
Old May 25, 2004 | 09:17 PM
luv2spd's Avatar
I have a 98 TA and ran into the same problem. Anyone know the fix?
Old May 25, 2004 | 09:22 PM
Magnus's Avatar
LS1TECH Sponsor
The only fix is to e-mail me.. so please e-mail me if you run into this problem. Thanks!
Keith @ HP Tuners.
Old May 25, 2004 | 09:25 PM
SLO POK 98's Avatar
Keith @ HP Tuners.
Thanks, there was an email sent to you with all the info from Scott Meshy, I was using his program.
Thanks again
-Mike-
Old May 25, 2004 | 09:30 PM
Magnus's Avatar
LS1TECH Sponsor
Mike, I do recall sending Scott an update. You guys are cleared away correct? I have no pending e-mails at this time.
Old May 25, 2004 | 09:32 PM
slow's Avatar
had the same problem, got it fixed within 3 hours or so
Ryan
