Lift are staying at 25
Old Jun 1, 2004 | 11:56 AM
White98Z's Avatar
Default Lift are staying at 25
It does not matter what i do ideal fuel throttle anything that is where thay stay.
HumpinSS's Avatar
you have a vaccum leak somewhere.
Old Jun 1, 2004 | 12:02 PM
White98Z's Avatar
That was quick i just was looking at my auto tap run and 10 min worth it never moves. Anything eles it could be
Old Jun 1, 2004 | 12:44 PM
jimmyblue's Avatar
Moderator
You would need one hellacious vacuum leak to
put you 25% lean, at any kind of open throttle.
Sounds more like the MAF is dead or disconnected,
O2s got killed or fuel supply is way weak.
Use ATAP to view the MAF output frequency, raw;
should be abour 2500Hz on an A4, maybe about
1500-2000 on a M6 (I only know the A4 for sure).
If you see a sane number at idle and it moves up
w/ throttle, MAF is hooked up & live.
View O2 sensors. They should bounce all over at
idle once warmed up. If they never get up over
500mV the car will think it's lean regardless of fact.
Lead, silicone poisoning will kill O2s, low temps will
make them "sleepy". Some time at high output will
bring "sleepy" ones around, until they cool off again.
A burnt O2 wire can make an output short, etc.
Gross fuel pump weakness, kinked / crushed line,
way-crusty filter could make for a fuel shortfall
but this is big, and even a poor fuel system ought
to be able to feed idle OK. So I would not expect
this one to be in the mix. Single dead injector
could add enough excess O2 to fake out engine
management, we can come back to this if neither
of the 2 best guesses pan out.
Old Jun 1, 2004 | 01:47 PM
SidewayzOZ's Avatar
Check your intake too, my best friend had this problem and it turned out to be a vacuum leak at the intake.
Old Jun 1, 2004 | 04:42 PM
Black02SS's Avatar
I had this problem when I installed my LSX intake. Turned out one of the vacuum lines was off.
Old Jun 1, 2004 | 11:53 PM
White98Z's Avatar
Well it is a new intake on the car and new computer wireing harness and computer. The thing is the computer is set up for a lot bigger motor then what i have. Now it back fires a little when i let off of the gas i auto taped it for about 5 min if some one wants to look at it and tell me what is going on.
Old Jun 2, 2004 | 12:06 AM
White98Z's Avatar
And what is the best way to check for a vacuum leak it reads 14 hg of vacuum plus this is not a standered intake i had to make my own gaskets.
