Vinci Handheld prgrammer
its like drinking from a fire hydrant, all this info hits you at once, haha
Can/how does that tuner adjust shifting points? and how about rev limiter?
That would be 500 rpm shorter than I want to shift.
I'm going to need my limiter set at 6800 too.
Easy to follow instructions, took a short time for VHP tuner to flash PCM.
Had to ditch the GMAF and went back to stock one.
Car stared fine, idled right away, exhaust note seemed more harmonious.
Took it for a drive to give PCM time to learn. Through town and traffic, then through a 50 mile highway ride at 80 mph on cruise control.
Car felt much better than before tune, firm and responsive shifts (still stock tranny till next week) W/TCI 3500.
A couple of WOT runs to 140 or so, acceleration was smooth and rapid, again exhaust note was less raspier.
I could feel there was a difference and one thing I noticed is at 80 mph, it was running 150 rpm less, which can mean that the car made the power to get to that speed a little sooner, by deduction, a power increase.
This was just with a:
stock cam performance tune
proper axle ratio,
tire height,
shift extention,
shift firmness.
I didn't mess around with other parameters, got to go to the track and do some N/A, and a couple of N20 runs, then we will see the improvements.
BTW before that I had a Diablo tune on.
I wish knew the parameters that are modified VS stock but all I have to say is that programmer rocks for a handheld and whoever programmed the tune knows his stuff for sure.
Can't wait till track day and some fuel/timing testing.
I am always running around in the low octane tables due to bad gas.I use booster at the track.I reset the PCM by pulling the fuses.I stay in the high table until that tank of gas with octane runs out.If i use this method at the track,what will happen to the tune when i pull/reinstall the fuses?
Also,can torque managment be shut off at WOT only?I would like to keep it for daily driving is possible.
Mahalo...
Do you think that I will be able to tune to the cam in my sig when the time comes? It isn't a Vinci/Crane grind, but a custom Comp grind.
Also, I am going to be swapping out my 21 lb injectors for 24.7 lb injectors...I checked out the tutorial and it looks like I can adjust for that...how accurate will it be?
Lastly, when does the GP end?
Thanks for all of the info!
-Billy
