dropped in LM7 on Nova, overheating, prolly needs tune?
idles great, but it overheats after driving after 20-30 mins,
it goes on "crawl" mode, put it on drive or reverse it wont even move!
new water pump, new radiator, im starting to think it needs a proper tune.
i used painless harness, painless said its plug and play but clearly
theres no much play happening.
so do you guys think i should take it for a tune? or fiddle around
with wiring, fuel pressure, intake etcccc. and try to diagnose further?
also anybody knows a good performance tuner in orange county CA area?
thanks guys
honestly im out of ideas, im about to just take this to a real mechanic lol
Several people skip this step and they have heating issues.
As far as running rough it sounds like another issue
As far as the overheating goes have you data logged it to be sure it is in fact overheating and not just the gauge going weird?
Also what do u mean you saw water drip when you took off the exhaust manifolds? Was is antifreeze? You should never have coolant coming from the exhaust manifolds unless it's in a boat....
it locks up like when i put it on drive it wont even crawl at all, when you give it gas it literally wont move like im pulling a 20 ton trailer attached in the back. im puzzled i dont understand it thats why im calling it overheating
What combo is in the car? Like what trans, specs on the motor and what Pcm/harness are you using
the injectors spitting put 42lbs which is too high for the stock 28lbs, broken oring seal on the oil pump shaft, shreded spark plug wire causing the 5th cylinder to misfire, melted o2 sensor wire, broken knock sensor wire.
replaced everything above and now its running strong, incan get actual tire spins now from accceleration.
