Knock Retard at wot
Knock Retard at wot
Still troubleshooting my issue, but I've got HPT now. Tried some wot pulls but my trans wouldn't shift from 2nd-3rd causing me to let off. I've also had the trans act up under normal driving, as if it intends to down shift when there isn't a need to, then goes back into gear. Here's my chart.
This is at idle, the b1s1 seems very unstable. That O2 was replaced since this issue started however so what else could it be?
02 LS1. Stock internally, lid and 3in cut out. The timing at wot was bumped 3* when I tuned out the rear O2's. It was 24* at wot at around the same RPM before the added 3* iirc. That was around 10k miles ago though with no issues at all until now.
The primary issue that started all of this is that the idle will drop when coming to a stop and sometimes die if I don't give it throttle. Sitting at idle after driving I'm hearing what seems to be a misfire. I've replaced all plugs/wires and MAF with no change. The plugs I took out didn't seem unusual. None were wet or oily.
Knock Retard at wot
Regarding trans:
make sure the WOT MPH upshift/downshift points are not upside down;
make sure the WOT MPH upshift points are achievable (i.e. rpm is not redlined);
set WOT RPM upshift points lower;
make sure the PT upshift/downshift curves do not cross each other;
set throttle kickdown tables to100% all across.
Since the car is still basically stock I re flashed the stock tune. Just deleted the rear O2's and changed gear ratio.
No KR now, but bank one is still too rich but in only in one cylinder. I'll upload pics shortly. I'm pretty sure it's the injector not working properly.
This is cruising on the highway. Bank 1 is staying rich.
Cylinder 5 plug, all others were clean. This is after only about 200 miles.
