Autometer playback tach reading low
I do have a blue and gray wire off the tach that are not connected.
Any suggestions? Thanks!!
Someone told me to tap rpm signal off a coil pack instead but haven't looked into it.
http://www.autometer.com/resources/index/faq_view/id/77
10k resistor connecting signal and power wires behind the tach, correct?
Link says " I recommend starting with a 10K-1/2 watt resistor, though you may go as low as 5K- ½ watt" so how do you tell which one to use other than solder, test, clip, solder, test, clip.... I expect a butchered harness in an area without room to butcher.
What can be done with a multimeter to get as close as possible for the first test?
