running/tuning without IAC valve?
Old Apr 24, 2016 | 06:37 PM
Hybredstang's Avatar
Default running/tuning without IAC valve?
Has anyone run or tuned a car with a cable throttle body without the IAC valve wired? I have a 2004 pcm and switching to cable TB. Do I absolutely have to get a DBC compatible PCM? I'd assume it would just kind of act like a carbed car and idle low when cold instead of adjusting according. Just wondering if anyone else has ever done this?
Old Apr 24, 2016 | 09:18 PM
2xLS1's Avatar
What is the service # on your 04 PCM?
Old Apr 25, 2016 | 04:03 AM
kingtal0n's Avatar
Its really annoying because, as the conditions change, the idle will change. it will be too low when you start and too high when its hot. A negative impact on drivability and economy.
Old Apr 25, 2016 | 07:27 AM
Service number is 12576106
I figured it would just act like a carb idling low until it warms up. I'm not exactly a tuner myself, but does HPTUNERS let you advance the idle timing before it reaches temp? I know that's not the exact best way of doing things, but it would keep the idle up.
Old Apr 25, 2016 | 10:32 AM
LSX Power Tuning's Avatar
We have run a few race cars with 4150 style TB's without IAC's and they work fine but thats a totally different animal. I would recommend just getting the right pcm, will save alot of headaches IMO. We sell them for $100 with a stock tune in them.
Old Apr 25, 2016 | 10:56 AM
2xLS1's Avatar
Service #12576106 with Hardware #12570558 has the IAC driver chip in it. All you would need is an Express Van file in it that is DBC.
Old Apr 25, 2016 | 01:19 PM
That's even better for the OP, that will save them some money and headaches.
Old Apr 25, 2016 | 04:03 PM
2xLS1's Avatar
Well he didn't say what the Hardware # is and it has to match too.
Old Apr 25, 2016 | 05:16 PM
The hardware # is the 12570558.
So what I'm seeing then is that this is a 2003 PCM but has the blue/green connectors like 2004+. Are the pinouts a 2003 or 2004?
I used this as the pinout reference when modifying my harness
http://www.lt1swap.com/2004vortec_pcm.htm
Old Apr 25, 2016 | 05:24 PM
2xLS1's Avatar
03 - 04 pinouts should be the same. I was going to say it was a 03 PCM but sometimes they can bleed over into the next year. Here is about everything you will need know about converting to DBC.
http://lt1swap.com/cable_conversion.htm
And LSX Power Tuning can help you with setting it up with the proper express van calibration if you don't have that ability.
Old Apr 25, 2016 | 05:47 PM
Yes sir, I found that page too. That's how I found out it was a 2003 PCM. I have a local tuner here I was going to take it to. I'll see what he has to say for the programming stuff. The motor is a 5.3 with the LSA blower. So I was planning on trailering it to him anyway.
I appreciate all your info. If I do need the express van stuff I'll get back with you
Old Apr 25, 2016 | 08:24 PM
2xLS1's Avatar
The Express Van is one of the few vehicles that used that PCM and had a DBC TB That's why you need to use as a starting point. Also there are both 2 and 3 bar SD custom operation systems available for it which you will want to use with that blower.
Old Apr 26, 2016 | 03:53 AM
natejk's Avatar
i just completed this swap in my truck pretty straight forward make sure you go into system options and change the dbw setting from 1 to 0 thats all you need to do after its wired
