Car wont rev past 4000rpms please help
I'm hoping someone else has solved this problem before I finally got my car running and everything seems ok, I take the car to get it tuned and its fine up until 4000 rpms and it breaks up backfires and cracks. Immediately I thought ignition so I replaced Coils, wires, and plugs, same issues. After that it must be fuel because a/f ratios goes nuts right at 4000. clean all fuel lines, injectors, new fuel filter. Same issues still
At this point I am replacing sensors, crank sensor, tps sensor. Still same issues car is smooth up until 4000. revs and drives smooth until that point. rev limiter is set at 7500 so its not that. I am thinking map or cam sensor but its just so weird to me. Fuel pressure is fine when this happens. It was driven 10 miles on a rough tune could the 02 sensors be messed up ? even though it idles at a great a/f ratio ? Running out of ideas here.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
I had a similar issue when I swapped in the 403LS2 motor. It would happen at 6300rpms and it had me stuck for about 2 months... I decided to swap in a new crankshaft position sensor in hopes that it would help... Sure enough the misfire issue was fixed and can now rev it to the moon.
If I were you, I'd throw in a new sensor and see if it does the trick. My car never threw a code for a bad sensor so I had no idea what it was...
