Since h/c, car idles like crap and now a code
A couple of weeks ago, I had the pp ls6 heads and the tsp 231/237 installed. The car was dynotuned by APE. Even at the initial start when I picked up the car, it would start, idle way down, hellasious lope, then idle would pick up a bit and it would seem to find itself at around 900 rpm. Took the cats off last weeks replace with racepipes and o2sims. Since the day I picked the car up, about 4 or 5 times your driving along in 4th or 5th and the car just stumbles like for a split second it fires on 7 cylinders. Today, while driving it did just that and then the SES light came on. Got home hooked up autotap and their were 5 codes, all the same, P0101 Mass Air Flow Sensor Peformance. What is this problem and what do I need to do to fix it?
I recently got the TSP 231/237 installed to and the other day just driving down the road I got a MAF code to. I cleared it and it hasn't came back since(couple of days).
Originally Posted by Pro Mouse
I'll be Damned ,You Got the problem from APE too?Sinse my 90mm TB and Intake install last week I get code PO102 MAF circuit Voltage to low.I mean to tell you when my car is Cold That Mother F'er gives me tons of crap to start,I have to goose the gas to start it when it is cold like an older Holley Double Pumper without a choke.I am Going back this week and Kirk is going to Fix it whether he wants to or not
I didn't know Kirk was still there. Wasn't he the old owner. Now its Chris. And yes, I'm going back this week also. Something is definitley wrong with this thing. When you first start it, it's a bitch to keep it running. Then when driving down the road, it like falls on it's face for just a second, but otherwise, it bucks and jumps, and now this code?
Scott
How's the MAF look? Maybe it needs a cleaning. Twice now I've noticed unusual, crappy idle. Both times, the problem went away after cleaning the MAF. I used some electrical contact cleaner, from radio shack, it comes in a small aerosol can with a plastic bristle brush.
good luck!
good luck!
I think it is safe to say that they over-tuned your MAF tables to compensate for your cam. Just my opinion though. What do your LTRIMS look like?
I found your problem. P0101 shows up when:
The MAF frequency is 50% different from the speed density calculation for at least 5 seconds.
What this means to me:
They messed up your tune. Check your MAF for sure though.
SS125 ,Did Chris and Kirk fix your Car?Is it running good?Mine wasnt the Tune ,Chris ,Kirk and I went thru it,My Problem was that POS Fast 90 mm TB!That thing is Junk!
