Cheap IAT from China: Resistance settings?
Has anyone used one of these,
http://www.ebay.com/itm/New-Air-Inta...dYUP90&vxp=mtr
I suspect the setting is similar to a camaro unit. I really don't know how I am going to get exactly 130*F air to blow on it though to test it. Any ideas or known settings is please?
First idea that came to me: hair drier + laser themometer = rough ideas? I suppose it only needs to be kind of close. And ambient temp would be a solid point in the middle. I am starting to think it wont be so bad after all.
Under normal circumstances, it is wise to avoid cheaply made parts from anywhere. Especially important parts. This is good general advice.
An IAT sensor is not necessary in my application. I run and drive the vehicle fine without one currently because I have enough experience and extra careful doing so. To that effect, I am not worried about an IAT failure, because it will not be used to make much if any changes to the fuel or timing (I will not allow it to do much) in my application (it does not get very cold here, and a wideband will alert me if it did. Any high temp changes are negligible as they tend to reduce fueling which is undesirable in the case of IAT failure). It is mainly going to be used for data-logging, and common sense can be used with this type of sensor to ensure accuracy, plus or minus a fair degree.
$0.02
$0.02
isnt the IAT used by the pcm to calculate air density? (ideal gas law)
without the iat the fueling will never be right.
The GM Cyclone uses a IAT sensor just like that one. you can get it from any auto parts store and it used common GM settings.
So that covers the cold IAT readings. Lets take a brief look at warmer temps:
When the air temp warms, the IAT is traditionally programmed to remove fuel. In a performance application, this is not going to happen (My IAT will never be pulling any fuel, ever. Nor will it be pulling timing or adding timing under any circumstances). Therefore, there will be no warm consderations for hot IAT.
This covers both hot and cold situations, as we see the IAT is useless for my fueling/timing considerations. However, it does help with keeping track (logging) of boost related temperature, which can be dangerous with pump fuel at high temperatures regardless of a/f or timing.
Last, consider that,
If you have a wideband, you can always make sure fueling is correct, and if it isn't, you grab the laptop and make it correct. Some people don't watch all the time, don't have the obsessive desire to constantly adjust their tune, but I do.
HI ALL, name one thing that is NOT Made In China ?
MOST ALL the MAT, CLT sensors are Made In China.
The buyers, one such is Delphi Purchasing, do "pick" their factories.
There IS a great difference in a quality China factory vs the low cost/low quality China factory.
The China EGO/UEGO Sensors DO NOT WORK.
The TPS sensors (CTS Knight) are Made In China.
The BEST way to check sensor calibration IS to immerse in boiling water.
Lance
Lance
