Is AFR500 wideband same size as AFX wideband ?
Like the Title , just trying to varify that the newer Ballenger AFR500 is the same size as the older AFX version as far as dimensions , I use to have the AFX and had it in the little cubby hole in the console and wanted to make sure the AFR500 would fit there too , thanks guys
https://www.bmotorsports.com/shop/pr...oducts_id/2337
All are made by ECM and have identical packaging dimensions. The only difference is that VERY early AFXs had a different case than later AFXs. The first rev was all translucent red enclosure. The second rev was a black enclosure with just a red translucent cover over the display.
