MS3 LSX Plug n Play Gold Box
Finally decided to do the right thing and instead of going the Microsquirt route, i went with the Megasquirt 3 LSX plug n play gold box from EFI Source. Im actually really excited to get it hooked up to the motor and start playing with the features. I do however have a question regarding the initial tune to get the motor started. From what ive read online and watched on YouTube, i see that there are factory setting available to load. But my motor is FAR from factory and would like to know where do i go to get a head start on what kind of tune will be required for start up and idle. Since im using such large injectors with a low base pressure, im assuming that my idle will be a bit difficult to tune without assistance. Tell me what other information you need from my build to point me in the right direction.
4.8 bottom end
Ported heads
LJMS turbo cam
210lbs HiZ Injectors running E85
S480 t6 turbo
Any guidance is useful so please feel free to comment or PM me
Thank you!
OX
Change the required fuel setting or scale the entire VE table for your smaller engine.
Done. You're not doing anything out of the box.
IT was wayyy off of course. But all the trigger wheel and ignition/dwell was apparently correct.
