Is it possible to tune the low-octane timing table?
The only problem I see is if you're running 87, and your ecm has put you into the low table, and you get some real knock it doesn't have anything to reference at that point. It already thinks it is in the safe zone. I'm not sure if they computer will continue to pull timing even if you're 100% in low table?
Just tune it to run 87 with no knock, then set the low octane at least 5 degrees less, if not 10 in the higher rpms. That's up to you and your engine.
https://forum.hptuners.com/showthrea...k+learn+factor
i see threads with both, good catch, gotta pay attention
another one
another one
I even double triple checked with them because I wanted to be sure
It's very odd that in the video you see it climb (as I have myself witnessed) as knock occurs. Strange indeed.
Off to check some logs... lol.
