EPC control
Old Jan 13, 2018 | 06:12 PM
maxz28's Avatar
Default EPC control
I have a 2001 Tahoe 5.3 and matching year 2001 4L60E transmission LS swapping to a 1989 K5 Blazer.
I want to convert the dual plug throttle body that came on it (2001/2002 DBW style ) to the 2003+ single plug throttle body.
I have the stock 2001 Tahoe 411 ECM RED/BLUE.
The 4L60E has been completely rebuilt. It obviously uses the 99-2002 EPC control.
Will swapping to the newer single plug DBW throttle body, harness and ECM cause shifting issues since the 2003+ ECM is looking for the 2003+ trans? Would I need to purchase all new 2003 EPC setup?
Is this programmable in HP Tuners?
Thank you to anyone that can help.
Old Jan 13, 2018 | 06:15 PM
Strictly out of nosiness, why do you want to switch to the newer TB??
Old Jan 13, 2018 | 08:23 PM
maxz28's Avatar
Better throttle body. Cleaner underhood wiring. Not having the freak year DBW throttle body and I’m OCD.
Old Jan 13, 2018 | 08:41 PM
Are you having any issues with the present TB?
Old Jan 13, 2018 | 08:49 PM
clinebarger's Avatar
You do not need the change the EPC.
Old Jan 13, 2018 | 09:00 PM
maxz28's Avatar
I’ve never used it. Never will.
Using a new Jet 2003-2006 DWB TB
Old Jan 13, 2018 | 09:02 PM
maxz28's Avatar
So all is well as is? They show different part numbers for the 99-2002 than the 2003+
PWM and TCC good as is too?
Old Jan 13, 2018 | 09:19 PM
They are different, Manufacturer & Connector....But functionally the same.
The early Holley made EPC is actually a better piece than the later Borg Warner EPC.
Yes, All other solenoids are compatible.
