Smogging a custom tune, etc.
I know guys have passed with the hi-lift Hot cam from WS6store. So how did they do it? They must have needed a custom tune.
Of coarse....They would need know if the CVN's are from GM or not, I highly doubt GM is required to surrender such info, Besides it would have to be updated almost daily.
Doesn't Cali put cars on rollers & measure emissions output?
They are suppose to visually check for catalytic converters, But they don't.
so the vin in the ecm cant be from a truck or suv. you'll have to use a car vin for the swap.
or, you can find someone to clone you an erod pcm that would pass.
other than that...register it at "grandpa's house" up in humboldt or one of the other no smog counties
vehicle after 2006: BAR/CARB database contains vehicle's VIN, calibration id, and CVN; this is the baseline, and any tuning is detectable.
vehicle prior to 2006: BAR/CARB database does not know the calibration id/CVN that the vehicle came with; i.e. their database has no baseline.
what I'm not sure about is this: with a 2006-or-earlier vehicle, when you show up for smogging at some point in time, do/did they store the calibration id and/or the CVN (which now becomes the baseline)...?
if they don't store the calibration id/CVN, then they won't be able to detect that the tune has changed.
Also, it seems they now check the readiness monitors in 2 steps:
a. they see what monitors are ready or not ready;
b. near the end of the test, they reset the monitors, they then check that NONE are ready;
so step b. weeds out any emissions defeat done to the tune.
my understanding is this (regarding earlier-than-2006 vehicles):
- if they do not store the CVN then they won't be able to detect any tuning.
- otherwise if they store the CVN, then they can compare the current CVN to any previous CVN they have on your vehicle (they may have been saving these since 2012, I'm not sure about this, I'm trying to find out more), so this might raise some questions (I haven't been game enough to try this yet).
