Anyone willing to help an F-Body out?
#101
Moderator
Received 1,838 Likes
Looks decent. At this point, you just need to start paste-multiplying your fuel trim data into your VE table to start dialing in the fuel
#106
The newest log with closed loop tune running the car around the block.. Takes a few to get to the closed loop stage. No pc hook up on this log, just MPV1 pro.. Still too new to tuning and appreciate the hell out of ChopperDoc for his videos on HP Tuners. 1 thing is for sure, once all this is said and done, tuning (through massive amounts of help through LS1Tech guys Darth and Chopper) progress, troubles / challenges and opportunities will be on this thread to hopefully help the next person.
#107
Moderator
Nice log. keep dialing it in. if you can, try to get as many cells as you can. very fuel-inefficient, but will shorten up the tuning cycle. I didn't look to see if you were in SD or blended mode. but at least it looks like everything is doing what it should now
#109
Moderator
So typical next step would be fail the mag and dial in the VE tables. Make sure to match your secondary table to your primary if your OS has both
