No spark but I have power and ground ?
Check all grounds. I had a similar issues while back with a new 6.0l I put in a friends truck. Ended up being a ground on the driver side by the motor mount that never was hooked back up
[QUOTE=Drj8787;20084286]Check all grounds. I had a similar issues while back with a new 6.0l I put in a friends truck. Ended up being a ground on the driver side by the motor mount that never was hooked back up[/QUOTE
okay what if I grounded the block from battery and my other grounds (besides the one close to the starter ) I grounded to my fire wall ? Would that be the reason ? It still has a good bare metal to the fire wall and my battery is also grounded good to chassis
i hope it’s not the crank! Hopefully it’s just the sensor . Does the sensor send the pcm a certain voltage ? If so what wire does this ?
