TCC Questions
Minimum TCC lockup is commanded at 29 mph in 3rd gear
I'd probably try manually controlling/commanding TCC Lockup with the VCM Controls feature, while logging.
That should help determine whether it's a mechanical or electrical issue.
I'd add some more transmission related channels as well.
Input/Output shaft RPM, TCC Slip %, Current Gear, etc...
If the converter was truly LOCKED at 8mph, the van would have very poor acceleration from most any RPM
Now I get to search through that and find the culprit, do you have any guesses on where to start? I wouldnt say the acceleration is TERRIBLE, but it's not exactly what I was expecting from the LQ4 I dropped in there Here is a great tutorial. Scroll down to the torque converter section.....
https://ls1tech.com/forums/automatic...tm-w-pics.html
T,
T,
