Harsh Trans Engagements 4L80E
I'm experiencing harsh engagements after the swap. When the engine is started, and the trans is shifted into "R", the truck bangs in pretty hard. This is exacerbated by the fact that the truck is 4X4 so there is extra "slop" coming out of the t-case. It also has a firmer-than-I'd-like "F" (forward) engagement.
Is there a line pressure adjustment that can be made using HP Tuners that would allow a lower line pressure (static line pressure) to aid in reducing the harshness of the engagements? I was able to segment swap this vehicle to get the correct OS installed, and get it up, running, and shifting. It's just the engagements are startling. The trans has a NEW EPC in it already. No codes being stored. It has over 500 miles on it since the swap and the engagements are the only problem at this point. All upshifts are firm, but livable. I have experienced this previously on vehicles that have high numeric gear ratios installed in the axles. This particular truck has 35" tall tires, and 4:56 gears in the differentials.
Any advise would be greatly appreciated. I posted here because it is potentially a "tuning" issue.
I forgot to mention that the truck has been tuned previously for a cam swap. Whoever did the swap has it tuned such that it flares pretty badly on initial start up-like up to 1300 RPM, and it has a fairly high idle for such a very mild cam.. It idles currently at 850. I mention this because I could set it to idle significantly lower in the P or N fields, and then raise the idle for the IN GEAR ranges (if it even needs it). It's a very mild cam, and they have it tuned as if it's got 230-240 degrees of duration. Probably a "canned" tune. I have not dug around in the engine settings side yet. I'm sure I could reduce engine idle speed, remove the extra air on start up to cure the flare, and then see where it's at from there. However, I think something is going to have to be done about the engagements even after that.
it doesnt have a whole ton of range though. I have a trans right now that had a slushy 1-2 that turned out to be the valve bore being worn a bit. I added a "shift saver" spring and even with the pressure vs tps zeroed on the 1-2 it'll still snap your neck if you arent ready for it. its coming out soon for a proper fix.
usually a big stall will eat much of a harsh shift if you have modded for high line pressures, but I have taken to adding wave plates in the fwd, direct and intermediate clutches so I can max line pressure for holding power and not knock my teeth out street driving.
i aim for 5 in the fwd and 6 in the direct with a cut down th400 piston....around .040 end clearance on both.
especially with the dual feed mod you need to keep an eye on pressures
