Misfire only under load - no codes
Bad lifter (if hydraulic), bent pushrod, bent valve or valve not sealing, bad spring or incorrect spring install etc.
Electrical question is, What/who's harness are you using? possible coil harness not correct. If using a stock harness, the signal wire for #1 cylinder should be red or purple. If its 1, then the other should be on #8. Red on 1, purple on 8 Or vice-versa.
finally fixed and posting for others that may be seeing similar issues. it turned out the I had 2 fuel injectors that although they were the same p/n, they were different brand than the others. Once I swapped in 2 new ones to match brand of the others, the problem went away. the cheaper imitations must have had a different flow rate or something.
