P1810 after trans install
I would contact Peformabuilt ASAP. IMO based on my experience with Alan for warranty 7 years after the installation, they warrantied my level III 100 percent and completely rebuilt it. They are decent to work with, but you need to call them to resolve the issue.
I would not continue to drive the car until you get the issue resolved. Line pressure can kill a tranny in a hurry
Are you sure the fluid level is correct. If the fill tube isn't installed correctly and secured it's possible to overfill and/or underfill. Ask me how I know that based on the shop that just recently installed my level III?
Frank
Did you actually see the transmission after rebuild from Peformabuilt before it was installed? Was it shipped to you or directly to the shop?
I sent you a PM.
With the 3600 Yank stall you might want to adjust shift timing and shift points etc. IMO some really good tips in this link for driveability especially for city cruising.
https://ls1tech.com/forums/automatic...tm-w-pics.html
There is likely a short or loose connection in the external harness that plugs into the transmission and/or internal wire harness inside the transmission.
There should NOT be any oil where the plugin harness connects to the transmission. If you have oil accumulation again there, it needs to be repaired. See link.
https://ls1tech.com/forums/automatic...g-top-pan.html
