Rpm hangs when I let off the throttle
Hey all,
Got a stick car with a gen3 6.0 that we just got up and running on Holley’s Terminator X. It has a Small cam and injectors and the software seems to be doing its thing pretty good.
One problem I have is the RPM hangs when I come off the throttle. It’s a DBC stock throttle body. The RPM’s start to drop in 2-3 seconds but obviously that’s no good.
Any suggestions where to look or what to tweek?
we are just starting to go thru this tuning process for fueling and haven’t messed with much of the stuff just yet outside of the normal wizard/configuration for injectors and such. Haven’t even touched the timing yet!
Vacuum leak. This screams vacuum leak somewhere. Check the edges of your intake manifold and throttle body with the engine running for leaks. An unlit but flowing propane torch or some starting fluid ether "explosion in a can" stuff can also help you find the leak. Keep a fire extinguisher handy.
Rick
Rick
Moderator
Received 1,838 Likes
Cut airflow from follower and cracker.
As to vacuum leaks. Best method involves a cigar and a glass of whiskey. Smoke the cigar and puff into the intake. Through the throttle and immediately let the blade close. After a few puffs you will see every leak you have.
The whiskey is necessary because nothing goes with a cigar like a good whiskey.
TB set screw was open and is now is all the way closed and both times the IAC reading was 0, This is a used TB, maybe it's defective but it is working coming off an at idle throttle blip so I guess I don't really know what to think. We'll throw a new IAC in there an see what happens. We also have a high rpm flair on idle for like 4-5 seconds we were chasing but I think we should get the iac to respond properly before we chase that.
If you haven't already guessed this isn't my car, I'm trying to help a buddy out and get his car working like it should. I'm a novice tuner at best and learned on HP Tuner. The Holley Term X Kit is really great at getting you in the ballpark really fast! I think it's just a matter of messing with **** until we get it right... Thanks for all the help here.
FYI, this is a 6.0 truck with a small Cam and FIC Injectors in a 71 Nova with a Nissan 6 speed manual, he says the car rips thru all the gears, we just need to work thru a few little things..
ALSO:
Not sure what my buddy changed but he says the RPM hang he was getting is now gone. It was not a vac leak.
ALSO:
Moderator
Was the throttle body ported? Sounds like the blade is not sealing
probably not, it was pulled from a stock truck but you never know. My buddy has a few other TB’s hanging around, if a new iac doesn’t do the trick another TB is a quick swap.
We’ll double check the blade/throat too for build up or obvious issues.
Thanks for all the suggestions!
🤨🤨🤨 lame! And used up. To the Nth degree. Lmao! Also most likely no the issue. Chased my tail with garbage motors info. Turned lut to be in the tune. Hun?? Whaa? Pfftftftftf. Everyone has an ******* er i mean opinion. lol
