Critique This Tune - C5 Corvette
2000 Corvette M6, Vararam CAI, LT's, Corsa axle back, 228/232 600 612 +3 111 LSA (8 degrees overlap), 243 heads shaved about 0.004" to clean up, Cometic 0.040 head gasket, LS6 intake.
Besides the general forum slowdown in the summer, the guys that are actual pro tuners don't hang out here all that much because they they're all slammed.
you might try the actual HPT forums too.
For your idle dip, I would try adding timing to the main spark tables as shown below. If it's not running the idle routine at the time it does it, this will artificially mimic the underspeed table and bump the timing when it sags which will raise the rpm. Just something to try.
I'd go ahead and do the same to the idle tables. Give it a whirl.
One thing about these issues and tuners. We need to live with the car for a week to work on this stuff. And we might not drive just like you do.
Even then, customers will always find the snivits!
Ron
