Rich during decel pulsewidth issue
im having an issue doing dfco disabled tuning I can’t get around.
during all decel it is going super rich, pulling 20% etc, however when getting on throttle it is pulling so much fuel it stumbles, even after a long coast down coming back to idle it is starving for fuel and stumbles until the stfts come closer to 0.
What’s interesting is the pulsewidths are LOCKED at 2.0 only during decel, any throttle and they accept the stft adjustments and go to 1.5ms etc and that makes me stupid lean until the stft comes back to near 0
does anyone have any idea how to fix this and let the injectors do wtf I have set in my VE table during decel?
I can’t remember the designator in efilive.
with large injectors it needs to be reduced or it causes what you’re seeing.
should I reduce this further?
By all means post the tune.
Transient fuel Min fuel milligrams is a somewhat confusing entry. Is it a limit? What happens if you set it to low?
Always seemed like the injector manufacturers should provide the correct number.
Having to redo my entire low end VE table. Pain the ****. I will post my tune when I get home and you can take a look. I’d like some insight on my spark table anyway as well, I have it in the dirt but now that I have this new cam tuned I’d like to start ramping timing down less aggressively. Car is PRC 225 with 62cc chambers but currently running ls9 gaskets and studs so probably 10.7ish:1 compression. Procharger car running 50/50 meth 12GPH nozzle progressive kit. Custom Martin Smallwood cam, 228/244 .612/.612 113+3LSA
