Throwing codes left and right today- HELP, PCM GURUS!!!
1. P0171- System too lean Bank 1
2. P0174- System too lean Bank 2
3. P0300- Random multiple cylinder missfire detected
4. P0171- System too lean bank 1
5. P0174- System too lean bank 2
I was thinking that the problem is either the fuel pump is going, the injectors are dirty, or the car needs new plugs (or a combination of those.)
What do you guys think? I really need help, I want to get the damn light off ASAP!!!
Thanks in advance.
pump/filter but doing this under load is not
so easy.
MAF molestation, K&N filter oil-spooge are
other possibilities (just how mostly, is
mostly?) if these are present.
Plugs will not cause lean codes but lean
operation will elevate misfire counts.
design) and it might want a cleaning if you have
been running a K&N. But, what it wants most is
proper tuning I expect. GMAF is a voodoo tune
for cars that run factory rich. 2000 models are
stuck with small injectors and a leaner "natural"
tune than the rich '98s that the GMAF (maybe)
helps.
Not to dissuade you from other preventive maintenance
but there's no point in dancing around the problem.
That MAF is a misfit to your model (and most others).
GMS is the only folks who claim different... funny, huh?
) Could the injectors use a cleaning?
