E85 5.3 cold issues / afr lean at idle no content sensor
- You said E85, but is it truly always E85? Some locations vary, some don't. Tuning for straight E85 without a sensor as long as it doesn't vary is not a problem and has been done since E85 came out.
Stoich for pump gas is 14.7:1 whereas it's 9.8:1 for E85
The sensor reads the mixture of pump gas to E85 and interpolates what Stoich is. Right now you're so far off the mark the o2 sensors cannot learn how to adjust the mixture and keep your engine running. Also you're likely to be dangerously lean if you apply any load to the engine.
As far as flex injectors; E85 requires a richer air to fuel mixture, hence the higher flow injectors (FYI OEM Pumps are the same pressure, flex regulator is a 3 bar and pump gas is 4 bar though). If your build doesn't exceed say 85% on existing injector pulse width then your injectors are likely good enough.
