98 PCM Questions
Hey all,
Been out of the loop for a good while but recently picked up a 98 Formula to mess with. More than likely this car will be a strong Heads/Cam NA cruiser and weekend warrior. Will I see any downside to just continuing to run the 98 PCM? People are quick to say 411 swap, but what benefit would I realistically see on say a 500HP NA type build?
Secondly, if I stay 98, am I better off HP or EFI Live or is it irrelevant? I appreciate the input.
I would swap it. Its really easy to do and gives you hp tuners tune ability. So changing speed limiters, skip shift, fan temps, removal of bs emissions codes that keep the engine light on.
i swapped my 96 lt1 car to 411 on a Saturday. For 98 to 411 its even easier.
The swap is not super easy as there's no plug-n-play swap harness. You have to repin.
But if it *does* fail, why not just change it then? In the mean time, you can tune the existing '98 PCM for all those things you have listed above.
