would big cam and ported heads on stock tune
would a big cam .591/.569 230/226 and fully ported heads with stock valves stock injectors and stock bottom end make it run crappy at more than half throttle but run great in park and reving up? if you still have stock tune on the pcm? trying to figure out what the problem is. Runs and sounds great at idle and reving up no misses. lopes good. but when driving it bogs when you try to take off fast or give it anymore than 1/4 throttle id this cause it needs to be tuned? thanks guys for any help
yes this is the same engine but the guy that did my heads tore them down and check all the valves they were fine just a little scratch up on the edges. The motor sounds and runs great at idle and revs up fast no misses so i believe the guy that did my heads why would he lie about it when i was paying him to replace them if they were messed up. Most people would say they were just to get paid from me. he said they were fine. so that is all i can tell you on that. I can send you a pic of the pistons and the heads if youd like me to. I just wanted to know if it not being tuned could make it run like **** that is my ?
What is the LSA on the cam?
LS1 Tech Veteran
Flippin,
As a minimum you're probably very lean when you try to accelerate and put the engine under some load. With that kind of lift and duration on the cam and ported heads, the volumetric efficiency table has to be off quite a bit which makes your air:fuel ratio out of whack (lean). Now, your stock injectors might also not be able to keep up with the fuel required at anywhere near wide open throttle.
If you want to see if your valves are sealing (due to being bent or damaged in any other way) run a compression check.
Another question: During porting, did they just hawg out the bowls and ports? For instance, if the swirl dam is removed, the swirl and therefore fuel atomization is hurt also making for low power. Also, big ports (improperly done) mean slower velocity which means poor atomization.
The long and short of it is you need to get some logging done on your vehicle (like with EFILive or something similar) and a WBO2 to know what's going on.
Steve
PS
Where do you live in Tennessee. I'm from Cleveland, TN originally (near Chattanooga). I live in Kansas now.
Steve
PS
Yes you will need a tune and and english class.
LS1 Tech Veteran
Flippin,
I'll get back to you in the next day or so. I've found some fairly good pictures and an article on proper head porting by Joe Mondello (possibly the most knowledgable head porter in the country) on the LS1. I'll try to send it this evening.
Steve
Steve
