Torque Management
Old Mar 2, 2005 | 08:49 AM
SgtB's Avatar
Default Torque Management
If i delete my torque management, how much damage will this do to my trans? Will I be taking years off of my trans. I do not drive my car every day and it only has $17K mile on it so all information on this would be appreciated.
Old Mar 2, 2005 | 02:04 PM
SgtB's Avatar
no one knows??
Old Mar 2, 2005 | 02:31 PM
horist's Avatar
I'm assuming you're an Auto right?
The damage caused by removing torque management really depends on how much you drive it aggressively... the purpose of torque management is to remove engine power before a shift so that the clutches can positvely engage easier under less torque/power... removing this presents a greater shock to the clutches
98s had very little torque management and there are still lots of them driving around on stock transmissions.
What I've done for some people that were worried about transmission longevity is I've removed 50% of the torque management ... they've all said it feels much better, and at the same time it's still pulling timing so it's still not as aggressive as no TM
But as mentioned, the damage caused depends on your driving habits.. lots of WOT blasts will take life off the trans regardless of torque management ... there's not really a number though of how much life is taken off...
If you're worried about it I'd say remove 50% of the TM ...
Old Mar 2, 2005 | 04:07 PM
matts22's Avatar
Can you remove TM at 100% throttle, but leave it for lower rpms? If that was possible, it would not hurt anything the majority of the time, but give more power when racing. Just a thought, I have an M6, but thought maybe this was possible. Is that what you mean by removing 50%?
Old Mar 2, 2005 | 04:12 PM
horist's Avatar
I just scale everything by 50% , but it is possible to just scale the higher load values down ... part throttle there isn't much Torque Management ... it's mostly at WOT ...
Old Mar 2, 2005 | 04:54 PM
SgtB's Avatar
yes it's an auto
Old Mar 17, 2005 | 05:41 PM
FelixIlka's Avatar
Horist, after I get some mods done, I gotta meet you and have you tune me for some $$ sence you aren't that far from me.
Old Apr 5, 2005 | 03:30 PM
CHRISPY's Avatar
Horist,
What are the names of the tables are you scaling by 50%?
