No luck with SD tuning, Help?
Drove the car and Ltrims were all -12.
I then decreased the Main VE Table by 92%. Drove the car again with no change all -12. I again decreased the Main VE Table by 92%. Still -12.
What is up with that?
Do I have to mess with the Secondary VE Table Also?
Does the IFR table have any effect on the VE table?
Thanks, Man
are you still running in closed loop?
the IFR table will make the injectors flow more or less but it will not DIRECTLY adjust the VE table (ie: adding 5% to the IFR won't add 5% to the VE table).......
if you are in open loop, when you make an adjustment to the VE table you should see a direct adjustment in air/fuel......
I made two different changes to the Main Ve table and did not see any change to my Ltrims, still -12.
